Adhesive Recomendation Needed
Ron Brauer
10-13-2001 20:12:57
I have an aluminum gas tank that was cast in two pieces. It was leaking on the seam so I took it apart to repair the leak. Need to find an adhesive to put it back together. The tank is about 1948 vintage and the adhesive was available then. Surely there is something made today that will do the job besides JB Weld. Any Ideas?
Ron
Chris C.
10-14-2001 05:41:27
 Re: Adhesive Recomendation Needed in reply to Ron Brauer, 10-13-2001 20:12:57
Ron, does this act as a sealer or does it actually work as an adhesive? Most motorcycle dealers have a oil/gas proof case sealer
(yamabond3 etc.) but it doesn't really have any adhesive strength. If this stuff has to actually take a load, there is a product called aluminum mend that has some strength good luck
canadian bodyman
12-26-2001 21:44:41
 Re: Re: Adhesive Recomendation Needed in reply to Chris C., 10-14-2001 05:41:27
Ron,
There are products on the market such as Duramix, Weld bond, 3M, that will do what you need they will hold the tank together. However when you get the tank together you need to seal it. There is a product (the name eludes me) that is used in sealing gas tanks on motorcycles and aircraft. See you auto parts dealer. Good luck.
