Restoration & Repair Tips Board
1968 JD 112 Variator/Fuel???
JTWalk
09-12-2004 14:48:00
I've got the variator off the tractor and my question is...How freely should the center sheave slide on the hub,and is there anyway to oil this.I noticed slight rust on the hub that is streaky & around the ends of the hub where the two outer halves go , but it is still shiny for the most part. Also,I've got the original manual and it recommends leaded gas. Is there any thing I should be adding to the gas(unleaded). I don't think any additives have been used before and I don't want to damage the engine.Thanks
