Restoration & Repair Tips Board
JD 60 Transmission
WD40
09-13-2004 09:16:15
I have a JD 60 and when you apply a load to it, the overdrive gear comes out of the stub shaft. The gear teeth have little wear and the pawl spring meets specs. The shifting rail has hardly no wear and the pawl does not show any signs of wear. Does anyone have any suggestions for this odd situation. All of the bearings were repleaced, so a sloppy bearing could not be causing this problem.
