Restoration & Repair Tips Board
Gas Tank Sealers
Ronn Boehlke
09-13-2004 09:27:33
We have several tractors that we are working on that need the gas tanks sealed. Can anyone give us some advice on gas tank sealers? What products have you used? Which ones work and which ones don't? Where to buy? Any info will be greatly appreciated. Thank you. Ronn
Kendall
09-15-2004 14:28:57
 Re: Gas Tank Sealers in reply to Ronn Boehlke, 09-13-2004 09:27:33
I used Kreem on both my Harley and Super A. I was happy with the outcome. Plug all holes, use plastic food wrap over the gas tank cap hole, reinstall the cap and that will keep the sealer from sealing the two together. Use a threaded plug on the fuel line so that the sealer wont fill the threads.
George Curran
09-25-2004 20:42:04
 Re: Gas Tank Sealers in reply to Kendall, 09-15-2004 14:28:57
hi i've used a product named 'seal all'just spead it on over the hole or rust spot you may have somebetter results if you useapiece of thin/open mesh frabic.and mix the seal all with the frabic .i've had gas tanks covered with this product works for me george
Weirsdale George
09-13-2004 14:26:17
The last sealer kit (sealer plus etchant) was from a motorcycle shop last year. Cost as I recall was $25 and will do probably three 10-gallon tanks if you are careful. As for which brands are better, I think I have used three different ones over the years and they all seem to be pretty much the same.
