Restoration & Repair Tips Board
F-20 Block Castings
Murphy
09-16-2004 18:59:30
Wasn't sure if message went across board so will post here. Neighbor has 1936 F-20 with a cracked block casting # 423DB. He has found a good block casting # 423EB. Whats the difference? Any problems on a EB going in place of DB? Any help would be appreciated.
Murph
JerePa
09-18-2004 17:23:51
 Re: F-20 Block Castings in reply to Murphy, 09-16-2004 18:59:30
Should be no problem. Check the newer one against the old one for ports, holes, etc to make sure. This casting was first used in the Regular tractor.
