Restoration & Repair Tips Board
560 diesel head casting numbers
super red
09-17-2004 17:05:33
I have a 560 diesel with a bad head I found one but the numbers are different was there different casting numbers for the same head thru the years that they were made if so what numbers would be the right ones? the one I found was804324 would that be for a 460 instead?
Jim J
09-19-2004 08:04:51
 Re: 560 diesel head casting numbers in reply to super red, 09-17-2004 17:05:33
Your casting number on the head that you found is 304324 and it fits a 460. The most common head for the 560 is 278368, the late 560's had 323771 heads and they were also on the 706 & 656. The 323771 heads are the big valve heads. I have put the 304324 heads on 560's with out any problems. What was the casting number on your old head? I could have a used head. Where are located?
