Restoration & Repair Tips Board
J.D. M final drive
DB
09-24-2004 10:03:00
any help on my final drive question from 9-17-04? The axle shaft itself can be pushed in and out 1/8 to 1/4 inch when the wheel is off. Not real sure how to take this apart and put back together, and what is probably causing it. if I where to shim the wheel out with some 2" diameter washers, would the axle continue to pull out?
vrickster
10-02-2004 13:41:11
 Re: J.D. M final drive in reply to DB, 09-24-2004 10:03:00
give me your email address and I can send you instructions for fixing the problem.
DB
10-06-2004 07:18:07
 Re: J.D. M final drive in reply to vrickster, 10-02-2004 13:41:11
Thanks vrickster, I appreciate it very much.
dnaburns@hotmail.com
