Restoration & Repair Tips Board
1953 Jubilee converted to 12 Volt - problems...
LEVIS
10-01-2004 17:24:50
This tractor was converted to 12V. It looks like a kit conversion. Problem: when hot,tractor sputters, runs rough & dies. Resistor on wiring post is hottt! Tractor has orig 6V coil.
I was told the coil went bad...to replace it with a 12V coil and add a balast resistor between the coil and distributor and remove bypass the old resistor. To hook hot side from ignition to the pos side of coil and run neg side to the balsast resistor and then to the distributor. Can anyone confirm this or refer me to a wiring diagram?
Bob
10-01-2004 21:13:25
 Re: 1953 Jubilee converted to 12 Volt - problems.. in reply to LEVIS, 10-01-2004 17:24:50
Since your Jub uses a conventional round-can ignition coil, just get a REAL 12 Volt coil that clearly states that an external resistor is NOT required, and save yourself all the resistor grief.
Assuming that you are set up 12 Volt NEGATIVE GROUND, connect the wire from ignition switch to (+) side of new coil, (-) side of new coil to distributor.
If you feel you need to make it difficult, and use a coil that needs an external resistor, ANY AND ALL RESISTORS GO BETWEEN THE IGNITION SWITCH AND THE COIL.
No resistors, EVER, between the coil and the points, OK?
Also, ballast or voltage-dropping resistors in coil circuits get HOT, even when the ignition system is operating properly. So a hot resistor is not necessarily an indication of problems.
LEVIS
10-03-2004 04:53:02
 Re: 1953 Jubilee converted to 12 Volt - problems.. in reply to Bob, 10-01-2004 21:13:25
Bob--thanks for the reply. Could I simply replace the 6V coil with a 12 V coil and use the existing resistor on the steering post as wired now? I have read info that says you need 3 ohms (volts?)running to the distributor. I could measure this.
The coil I have purchased is typically used on a 57 chevy with a resistor (local mechanic"s recommendation). I suppose that the resistor that is paired with this coil (O"Reilly autoparts states this is it"s match) would go up on the steering post? Will "any" 12 V coil that doesn"t req. a resistor work? Or is there a specific auto year or type?
By the way, the orig. problem fried the key switch. When the switch was replaced and ignition is on I could smell the resistor (wire smell) getting hot long before I burnt my fingers. Just how hot do they get?
Bob
10-03-2004 09:47:32
 Re: 1953 Jubilee converted to 12 Volt - problems.. in reply to LEVIS, 10-03-2004 04:53:02
I would use the recommended resistor with the coil you have, rather than the original, if it's too late to return the coil and get a "real" 12 Volt unit.
If you go the other route, a "generic" 12 Volt coil that does not need an external resistor should be fine. (NOT application specific.)
The ballast resistor will be quite warm in normal operation, and with the key "ON", engine NOT running, points closed, it will quickly get hot enough to burn you!
Good Luck!
