Restoration & Repair Tips Board
Serial numbers?????
docrob2001@yahoo.com
10-04-2004 22:19:59
I am fixing up a Farmall model M and don"t understand the serial number bit....serial number FBK 29574 XI....If I am correct then this tractor was built in 1942....is that correct
Kendall
10-05-2004 07:06:56
 Re: Serial numbers????? in reply to docrob2001@yahoo.com, 10-04-2004 22:19:59
FBK = prefix for Farmall M
29574 = 1941
X1 = gasoline
Guy Fay's IH tractor data book
10-05-2004 19:49:36
 Re: Serial numbers????? in reply to Kendall, 10-05-2004 07:06:56
thanx...you wouldn't happen to know the firing order for this tractor would you....
Joe (Wa)
10-06-2004 08:22:00
 Re: Serial numbers????? in reply to docrob2001@yahoo.com, 10-05-2004 19:49:36
Tune up specs.
pg
10-06-2004 03:16:26
i do believe the firing order is on the side of the block... pg
