Restoration & Repair Tips Board
Farmall H starter
Muley
10-05-2004 15:59:21
I have a 1952 Farmall H. The starter occasionally hangs up (6 volt). Teeth on both starter and flywheel look good. To unhang it I have to loosen the starter bolts and rattle it a bit and tighten it back up and she fires right up. Any ideas on how to fix this. It always seems to happen when I am in a hurry!
Thanks.
Gordon
10-08-2004 08:46:21
 Re: Farmall H starter in reply to Muley, 10-05-2004 15:59:21
The starter is misaligned. Try a small shim at some point . If it doesn't help, move the shim 90 degress and try again. Keep shimming until you find the source of the problem.
Gordon
Larry in CO
10-06-2004 18:12:07
Muley,
My H hangs up the same way once in a while. I've found the easiest way to get it unlocked is to put the tractor in 5th gear (WITH IGNITION OFF) and rock the tractor. Usually a couple of good rocks will pop the starter loose and off you go. So far, Ive not had to loosen the starter using this method.
HTH,
Larry
CNKS
10-05-2004 17:20:36
There is enough wear on one or the other to cause it to hang up. My Super H does the same thing.
Red Ed
11-10-2004 17:52:13
 Re: Farmall H starter in reply to CNKS, 10-05-2004 17:20:36
To unlock the starter put it in neutral and roll the engine over with the hand crank, WORKS EVERY TIME!!!
