Restoration & Repair Tips Board
George Md What kind of rod do you use on cast iro
Nicholaus Sowde
10-10-2004 20:09:45
George Md What kind of rod do you use on cast iron? With Oxy Acy torch. Thanks
ken tubrett
01-08-2005 17:58:58
 Re: George Md What kind of rod do you use on cast in reply to Nicholaus Sowder, 10-10-2004 20:09:45
use a nirod 55 grind out crack first then pre heat metal with torch weld crack reheat cover with a fire blanket allow the weld to cool down slowly
george md
10-10-2004 21:21:32
Nicholaus,
The rod is cast iron in stick form , usually use 3 /16 or 1/4 inch , it is usually square but some brands are round . Two brands that I have here are harris- welco kast weld 111 and the other is from tucker valve seat co in odessa tx . welco has a very good flux to go with the rod , flux is a must have , can't weld without it. I'll send you an email also.
george
Gauger
10-24-2004 07:19:44
 Re: George Md What kind of rod do you use on cast in reply to george md, 10-10-2004 21:21:32
George, I take it you are in the business of welding. I have a distillate manifold that I took to a "professional" weld shop. They should be embarassed for the cobbled mess they created and I should be shot for paying them. Can you send me an email with your contact information? Geoff Gauger
Alberta Mike
10-14-2004 05:05:51
George, ever here of this for welding cast? It was a little article in an old farm magazine from the 30's that my friend picked up somewhere. The article says you can torch-weld cast by making your own welding rods using old (clean) piston ring segments with thin copper wire wrapped around the segments of piston ring. Don't remember what the article said the copper did (whether it acted as a flux or for some other reason). Sort of interesting and was wondering if you've ever used it or heard of it?
george md
10-14-2004 17:03:41
 Re: George Md What kind of rod do you use on cast in reply to Alberta Mike, 10-14-2004 05:05:51
Mike,
Yes , I have heard of the piston ring and copper but I have never tried it . Back then rings were
all cast , now many of top the are moly , chrome , or
chrome faced . The material sheet for the cast rod says it has .01% copper in it . I'm not sure what purpose the wire would serve. george
Little Dave
10-10-2004 21:21:24
Grind it clean and you can weld it with brass.
george md
10-10-2004 21:28:37
 Re: George Md What kind of rod do you use on cast in reply to Little Dave, 10-10-2004 21:21:24
Little dave ,
Brass is way better than arc weld , but NO
where near as good as oxy/acet cast iron weld.
Link below , a necessary read if you weld cast,
about 3 or 4 pages . If you read carefully you
will notice that he says arc is the worst choice.
george
