Restoration & Repair Tips Board
Exhaust Manifolg 574 IH bad threads
Hollisterclay
10-19-2004 08:01:16
I recently purchased a Int 574 utility, the muffler was loose, and I found that the 2" pipe going into the manifold from the muffler has the threads messed up,a local dealer told me that it is near impossible to re tap it. it seems to me his would be a common problem. any advise on a solution would be greatly appreciated. Thanks in advance!
Randy Clay
Phil from Maryland
11-03-2004 18:37:40
 Re: Exhaust Manifolg 574 IH bad threads in reply to Hollisterclay, 10-19-2004 08:01:16
I had the exact same problem with my IH 404. My neighbor is a plumber and has every possible tool for working on pipes you could imagine. A quick stop to his place and I had a 2" (I think it was 2") thread cutter. greased it up and it easily re-cut the threads. The threads were really rusted and someone had used JB weld compund like you would use on a radiator to seal a leak.
It was simple. I also re did the threads on the pipe as he had one of those tools as well.
I would recommend going somewhere else if they cannot do something as simple as re-cut threads. It took me 15 minutes. It was not hard at all.
