Restoration & Repair Tips Board
Case 580 CK Davis Roadrunner Backhoe/Trencher
JOn Bryan
10-24-2004 19:55:46
Anybody heard of this? Parts availabilty? I just bought one for a few hudred bucks that needs the ram that lifts the trencher (totally missing)
Ken H
11-23-2004 20:40:14
 Re: Case 580 CK Davis Roadrunner Backhoe/Trencher in reply to JOn Bryan, 10-24-2004 19:55:46
The case 580 ck was a basic tractor, and it sounds like the trencher might be a bolt-on.
A photo might be helpful to quess further.
T_Bone
10-27-2004 02:16:53
Hi Jon,
Lift the trencher arm to the hieght you want it, then measure between centers the mounting holes then subtract 1" and that will be the double acting cylinder length required.
You would also need to consider the digging depth. You might need a longer cylinder to reach maximum design digging range thus the trencher arm would carry lower than you think it needs to be.
Alot of companys carry new hydraulic cylinders. Find one that closely matchs your existing cylinders style. I doubt if you will find a OEM.
Bore size would probably be in the 3" range.
All this is just a SWAG on my part as I never seen your model of trencher.
T_Bone
