Hand clutch problems on AC D-14
Steve
10-14-2001 14:14:30
I have no neutrual on my AC D-14. I have to physically hold it back hard to get to engage in LO range. I have no trouble with HI range it locks in fine. When the lever is in the N position the tractor still wants to move in the direction of the gear you have it in. Any sugestions.
JMS/MN
12-28-2001 18:45:53
 Re: Hand clutch problems on AC D-14 in reply to Steve, 10-14-2001 14:14:30
Creeping in neutral is nothing new. Other problems- I would check the shims that are between the clutch packs. Remove the cover on the right side of the tractor by the brakes. Check with the service manual for proper shim thickness and adjustment, and number of shims. Also check condition of clutch plates.
