Restoration & Repair Tips Board
Leaky Radiator in Farmall M
bob4knee
11-06-2004 16:21:25
Hello all,
I finally put a thermostat in the used M I got last spring. (Used an autozone #800-180-thanks Bob M!). Tractor now warms up nice, coolant heats up and pressure actually builds (maybe for the first time in a long time). A few weeks ago I drained the rusty coolant, and flushed the system (used some gunk flush additive, and lots of clean water). The drain tube on the radiator (a 6 inch nipple) was packed solid, I had to take it off and hammer through the packed goo.
Well, now the radiator leaks. Probably due to finally getting warm enough to build pressure more than the flush, but that probably helped to. I'm thinking I ought to figure out how to take it off, and run it into a radiator shop in town, but I'm guessing the steering shaft needs to come off first, and it looks like that's been on there for 60 years.
When I used to work in the car-parts place, I'd laugh at the folks buying the "bars leaks" and other radiator sealant products. I figured that stuff can't be good for the rest of your cooling system. But now I'm wondering. What would be the down side of putting something like that in? Would it just last till it got really cold and I'd have to fix the thing in the middle of winter, or has anybody had any luck with such additives? If so, which brands?
(Guessing the answer to the above is "fix it right") Is there a recommended shop manual for this? I see one in the farm&fleet that looks like it covers 20 different IH tractors (and it's none too thick anyway). I think those were 20 or so bucks). Is there a better reference? I see that I need to remove the steering shaft, but can't really see how the radiator is attached to the tractor.
On the plus side, the tractor has lots more power than it did when the temp was only getting to 100 F. Thanks again for the T-stat advice.
Bob
TDK
11-06-2004 21:35:10
 Re: Leaky Radiator in Farmall M in reply to bob4knee, 11-06-2004 16:21:25
You can go either route, remove or use "Bars Leaks". If you decide to remove, get an I/T manual and/or send me an e-mail and I'll talk you through it. If you decide to use "Bars Leaks" then I would recommend this. Lots of people put this stuff in system and just leave it. This is a mistake in my opinion. Instead, drain your antifreeze; refill with water & "Bars Leaks"; run until hot(let it circulate a reasonable amount of time);shut tractor off. After it has cooled(next day) drain & flush with water; refill with antifreeze/water. It may not harm anything by leaving the "stuff" in there but it sure makes the coolant look nasty.
msb
11-06-2004 18:34:27
Nothing wrong with using Bars Leaks.It only works when it is hit by air.The air dries it up and that is when the leak stops.Old timers used all sorts of things as stop leak.Pepper, cinnomon,nutmeg to name a few.They all worked the same way as BarsLeaks except Bars Leaks comes mixed in miscible(sp?) oil.
