44 Farmall H Exhaust Manifold
Ron
10-14-2001 17:51:48
Is there a way to patch a hole in the manifold, that will last for a "while"?
Slappy
10-30-2001 04:26:39
 Re: 44 Farmall H Exhaust Manifold in reply to Ron, 10-14-2001 17:51:48
Ron, I have an old distillate manifold that I pulled off my '44 H. It had gotten water down it and froze, which cracked the body, but as far as I could tell the intake/exhaust is still separate and the tractor ran great with it on. I pulled it off because I and restoring the H. I was going to throw the old manifold away but if you want to pay shipping it's yours. Darn thing is heavy though, may cost a little to ship it. I'll check if you want me to.
Ron Ackles
10-30-2001 11:14:09
 Re: Re: 44 Farmall H Exhaust Manifold in reply to Slappy, 10-30-2001 04:26:39
Slappy,
Thanks for the reply. Yes, please check possible freight cost for me, if you will.
Ron Ackles, 14206 Flying W Trail, Helotes, TX, 78023-4081
Thanks
Ron
Ray M41
10-15-2001 18:12:04
I patched my M's manifold with pieces of copper cut from 2" type L copper pipe. I tapped them lightly with a small hammer to match the shape of the pipe. I then wrapped the patch with #10 ga. copper wire and silver soldered the ends. I then lined the inside with high-temp muffler and exhaust pipe sealant. Got about five good years out of it till I found a nice used one. Use one of those toothbrush sized wire brushes to really clean the inside before you start with the patch.
Ron Ackles
10-30-2001 11:16:06
 Re: Re: 44 Farmall H Exhaust Manifold in reply to Ray M41, 10-15-2001 18:12:04
Ray,
Sounds like a good idea. 5 years might be my life-time.
Thanks,
Ron
Gene Davis
10-14-2001 21:02:35
Do a web search for "POR-15", they have a manifold repair product, and also paint for manifolds. Gene Davis
Ron
10-15-2001 11:53:03
 Re: Re: 44 Farmall H Exhaust Manifold in reply to Gene Davis, 10-14-2001 21:02:35
Gene,
Thanks.
FIRE SEAL 2000, by POR-15.
Ron
