Restoration & Repair Tips Board
MOLINE RESTORATION
BUD BARENIE
11-17-2004 19:37:29
I have a MOLINE G , I'M going to start restoration on this winter. Is their any other way besides sandblasting to get the chassis clean and prepped for primer. I have a pressure washer and don't mind hard work, just want the casting's to look great. SHEET METAL I'LL WORRY ABOUT ON THE LAST PART !
ALL advice helpfull.
Albert Grindle
11-26-2004 08:22:06
 Re: MOLINE RESTORATION in reply to BUD BARENIE, 11-17-2004 19:37:29
A 4" angle grinder, as mentioned before, was a good, inexpensive choice for me. It might take you awhile, but your chassis will look great
smoky
11-24-2004 06:33:25
If your cast iron has original paint, and no flaking paint, cleaning and roughing/dulling the paint should be sufficient. If totally grease, dirt and solvent free, the original paint will act as a effective primer for your paint. Generally speaking, cast iron was not primed new, just painted as the roughness of the surface gave adequate bite for the paint.
jason(ma)
11-20-2004 09:53:53
On my farmall f-12 I bought a couple of wire wheels for a 4" grinder and did the trans/frame that way. I'll attempt to link my pic here, if it doesn't work, do a search for a 1934 F-12 under the pic's and you should see it. J
