Restoration & Repair Tips Board
Farmall Super C or Not?
WPTerry
11-25-2004 09:07:26
I have what I assume to be a Farmall Super C which I think is a 1951 Model. I"m going to attempt a restoration God help us all! The Serial Number is "130844". This is on the small plate attached to the tool box under the seat. The plate has been painted over several times and is hard to read. On the plate there appears to be a "FO" following the word "Model".
Can one of the Farmall experts confirm that this is a Farmall Super C? And also can someone indicate if the "FO" makes any sense to someone?
Thank you for any assistance. Happy Thankgiving everyone! Bill (Tractor Restoration Rookie)
Red Dave
11-29-2004 06:56:17
 Re: Farmall Super C or Not? in reply to WPTerry, 11-25-2004 09:07:26
If you have 6 digits in the serial number, it is a Super C.
CNKS
11-25-2004 17:03:53
Both C's and Super C's were produced in 1951. The prefix for both is FC. Assuming your serial is correct, you have a late 1951 Super C, likely assembled in December. Serial numbers can be found on this site to the left under "Research and Info". Super C's had disk brakes (cast housings) and curved clutch and brake petals. Regular C's had band brakes (stamped housings) and straight clutch and brake petals, among other differences.
WPTerry
11-26-2004 17:41:22
 Re: Farmall Super C or Not? in reply to CNKS, 11-25-2004 17:03:53
CNKS - Thank you for taking the time to respond to my question. The prefix of FC which looked like a FO to me makes sense. Is there a link or manual that lists the Prefixes and what they mean that you are aware of? I may try and get some of the old paint off the serial plate. That way someone might be able to read it! I saw the serial number section and it seemed to confirm that it was a 1951 Super C but the mistaken FO threw me off.
Thanks again.
CNKS
11-28-2004 17:46:51
 Re: Farmall Super C or Not? in reply to WPTerry, 11-26-2004 17:41:22
FC is simply IH's designation for Farmall C; FAA is Farmall A; FAB, Farmall B; FBH, Farmall H; and FBK, Farmall M. This is only a partial list.
greenmech
11-25-2004 10:34:22
You have one to many numbers in the serial. And the FO sould be FC.A 51 would have#71880 to 80432
WPTerry
11-26-2004 17:56:49
 Re: Farmall Super C or Not? in reply to greenmech, 11-25-2004 10:34:22
greenmech - Thank you for the quick response. I'll check again on the serial number plate after I get some of the old paint off. I think I have 6 numbers in my serial number (130844). Are you saying there should only be 5? That doesn't seem to match up with the serial numbers listed in the serial number section on this website for a Farmall Super C. I'm a rookie at this so I could easily have missed something. I'll look for the "FC.A51" prefix you mentioned after I get the paint off.
Thanks again.
greenmech
11-27-2004 21:16:28
 Re: Farmall Super C or Not? in reply to WPTerry, 11-26-2004 17:56:49
Sorry ,I was looking at regular C numbers. Good luck with your tractor.
