Restoration & Repair Tips Board
Drilling out brads?
walter squires
11-29-2004 07:53:25
On my JD H I would like to remove the serial number plate before it goes to the hot tank, these brads are so hard a center punch won't touch them, I know I can knock the heads off but I still need to drill them out to replace the tag with new brads.
An suggestions would be appericated.
JD_IHC
12-03-2004 07:19:09
 Re: Drilling out brads? in reply to walter squires, 11-29-2004 07:53:25
They are probably escutchion pins. If so they have coarse spiral threads. Use a thin cutoff wheel to slot them, then back them out with a screwdriver. You might need an impact driver to get them started.
Bguy
11-29-2004 09:02:07
Walter, I always remove these when doing a restore so I can clean the tag up good and paint behind it. I slot the head of the brad with a dremel tool and use a screwdriver to back it out just like a screw. Replacement brads are available from your JD dealer. You are right, I don"t know what these things are made of but they are dang near impossible to drill out.
msb
11-29-2004 22:00:37
 Re: Drilling out brads? in reply to Bguy, 11-29-2004 09:02:07
Sometimes it is easier to drill new holes right next to the old holes.The plate will cover them if done right.I usually use a small sharp chisel and drive it under two sides a litle bit at a time.If you can get them to move,they are pretty easy to pull with a very very small nail puller.
