Restoration & Repair Tips Board
Ford Powermaster grill needing work or replacement
T.B.
12-06-2004 14:34:40
I have a Ford 841 Powermaster with a grill that has sections to it, unlike a lot of the hundred series fords other than Powermasters. Anyway, it has a fair number of dents in it and I would like to get the whole tractor back close to original. Is there somewhere I can send the grill or should I try to find a replacement. I know it is beyond my abilities and I am hesitant to turn it over to an autobody shop (should I be hesitant?). Where could I find a replacement?
JK in SOCAL
12-12-2004 23:40:48
 Re: Ford Powermaster grill needing work or replace in reply to T.B., 12-06-2004 14:34:40
I have one sitting by the barn. Grille and dirt screen. Pretty fair shape, not beat up. Has some surface rust that will bead blast away easily enough. I don't have the bottom section, though.
e-mail: ra5c@att.com
john in la
12-09-2004 05:44:33
What part of the grill are you talking about??
The egg crate cover????
If so I would think any auto body shop could repair it if it is not to far gone. Would be good to at least let them look at it and give you a estimate.
If you are talking about the dirt screen; you will need to replace that as I do not think it is repairable.
If you are looking to buy either one used you could contact a guy named Brian to see if he has a replacement you could buy.
You can e-mail Brian at..... ...
brian at ungerphoto dot com
(you will know how to make this spam prevention address work)
He also sells a lot of Ford parts on e-bay under the user name of "fordtracman"
