Restoration & Repair Tips Board
Converting a 6-volt generator to 12-volt
Geoffrey in KS
12-09-2004 12:16:09
Can someone tell me what needs to be changed inside a 6-volt generator to convert it to 12-volt? I have had this done a couple times, but it is time for me to start doing my own. It needs to be rebuilt anyway and I don't want/can't use a replacement generator or alternator.
Thanks,
Geoffrey
Gene Davis (GA)
12-09-2004 19:20:18
 Re: Converting a 6-volt generator to 12-volt in reply to Geoffrey in KS, 12-09-2004 12:16:09
You will need a set of 12 volt field coils, and the armature will need to be rewound for 12 volts. Then you need a 12 volt regulator and then change the ignition coil to 12 volt, or add a resistor block. the electrical gauges will have to be changed to work on the higher voltage. The 6 volt lights will last about 2 minutes and go out with a blaze of bright light, so they will need replacing with 12 volt units also. Gene Davis
Kenneth
12-19-2004 10:57:01
 Re: Converting a 6-volt generator to 12-volt in reply to Gene Davis (GA), 12-09-2004 19:20:18
Gene,
If your still in need of the generator parts, armature, fields regulator let me know as I have these items.
Kenneth
Classic Generator
www.classicgenerator.com
817-473-1448
Geoffrey in KS
12-10-2004 11:07:29
Gene,
Thanks for the info. I've got the rest of the conversion down, but I didn't know about the generator itself.
Thanks,
Geoffrey
Gene Davis (Ga.)
12-13-2004 18:06:44
 Re: Converting a 6-volt generator to 12-volt in reply to Geoffrey in KS, 12-10-2004 11:07:29
It may be cheaper to purchase a used 12 volt generator to do this job if you can find one in a salvage yard, or some rebuild shop.
