Restoration & Repair Tips Board
FAIRBANKS MORSE MAGNETOS AND DISTRIBUTOR GEAR
KENT FRITTS
12-16-2004 17:55:12
WOULD ANYONE KNOW HOW TO REPLACE THE DISTRIBUTOR DRIVE GEAR ON A FAIRBANKS MORSE MAGNETO AND HOW TO TIME THE DRIVE GEAR ONCE IT IS INPLACE. THE SERIAL # ON THE MAG IS 7424557 IT ALSO HAS A MFD FOR # L-2677 AND A FMX4B16A-1 STENCILLED ON THE SIDE. ANY HELP WOULD BE GREATLY APPRECIATED.
Earl S.
12-17-2004 14:18:21
 Re: FAIRBANKS MORSE MAGNETOS AND DISTRIBUTOR GEAR in reply to KENT FRITTS, 12-16-2004 17:55:12
I looked up your mag in the Fairbanks manual.Its on a Continental, clockwise rotation. You want to replace the rotor drive gear or the gear that is on the armature.email answer. Earl
Kent Fritts
12-18-2004 07:44:46
 Re: FAIRBANKS MORSE MAGNETOS AND DISTRIBUTOR GEAR in reply to Earl S., 12-17-2004 14:18:21
I've gotten more info but not all I need. There are two gears inside the mag- a small steel gear that goes to the armiture and a larger fiberglass gear that goes to the rotor. The steel gear has a small marking on one gear that is suppose to line up with a marking on the fiberglass gear. There are two marking- an A and a C on the fiberglass gear. These markings are two cogs apart. Do I line up the marking on the steel gear with the A or the C. I was told to put it on the A but when I took another mag apart it was on the C. What is the purpose of having two markings on the fiberglass gear? Are there certain times when you would use the A and the C? What do those letter stand for? Any help would be greatly appreciated.
Earl S
12-18-2004 14:12:17
 Re: FAIRBANKS MORSE MAGNETOS AND DISTRIBUTOR GEAR in reply to Kent Fritts, 12-18-2004 07:44:46
Bob is correct you determine the mag rotation by looking at the impulse drive. Earl
Bob
12-18-2004 12:08:51
Use the "C" mark for a "clockwise" rotation mag, and the "A" mark for an "Anti-clockwise" mag.
Apparently, years ago "Anti-clockwise" was more P.C. than "Counter-clockwise"!
I believe rotation is determined when you are facing the impulse drive, but I'm sure someone will correct me if that's wrong!
