Restoration & Repair Tips Board
Wiring 12 volt Starter Solenoid
elsinorerm
12-20-2004 13:06:29
Hello,
I have an 8n and I'm needing to replace my 6V, 3 post starter solenoid with a 12V, 4 post one. part# 311006. Before, the starter button was connected to the post marked "I" and there was no "S" post. On the 12v solenoid, there is now a post "I" and "S". What is the proper wiring setup for this?
thanks,
Rich
elsinorerm
12-21-2004 18:05:40
 Re: Wiring 12 volt Starter Solenoid in reply to elsinorerm, 12-20-2004 13:06:29
Thanks John, that exactly the info I needed. I have been looking through hundreds of posts and have not come across anything with this detail. All the other diagrams I have found leave off the "S" post. Kind of important info. Anyways, thanks again,
Rich
john in la
12-21-2004 15:46:08
Well I got to disagree with Bob.
Part # 311006 is a 12V relay off of the 801 diesel. It is a grounding relay unlike the power relay used in cars.
On your new relay the power comes in the I terminal and is grounded through the S terminal.
So you need to run a wire from your terminal block (side that is hot only with key on) to the I terminal. Then run a wire from the S terminal to the starter button on the trans.
While I wrote the following article for the hundred series tractors with a Delco alternator conversion the later 8N's with the side mount coil is very close. The brackets and some markings are different but you may be able to convert to understand your 8N conversion better.
Hundred Series 12V Conversion
Hundred Series 12V Wiring
Section on starter relays
john in la
12-21-2004 15:48:49
 Re: Wiring 12 volt Starter Solenoid in reply to john in la, 12-21-2004 15:46:08
Sorry the wiring diagram link did not work so lets try it again.
The address is http://216.167.44.209/programfiles/talers/conversion%20diagram.png
Bob M
12-21-2004 07:42:13
Rich - Connect the pushbutton to the "S" terminal. (Nothing gets connected to "I" in your setup...)
