Restoration & Repair Tips Board
Cummings 5.9 Engine
GRL
12-28-2004 13:24:27
Well the timing cover has a nice big hole in it, any one want to comment on it?
JimKS
01-04-2005 23:58:26
 Re: Cummings 5.9 Engine in reply to GRL, 12-28-2004 13:24:27
I ran into that once- a bolt holding the aluminum gear housing to the block came loose, the cam gear grabbed it and put a hole in the gear housing, just under the fan hub. Cummins came out with some new fancy bolts to prevent that problem, and a better gear housing gasket.
fox
12-28-2004 18:55:09
Did the dowel pin come out? This pin aligns the timing case to block. What year is it?
Bob
12-28-2004 15:09:45
Clessie's last name was CUMMINS.
GRL
12-29-2004 19:53:41
 Re: Cummings 5.9 Engine in reply to Bob, 12-28-2004 15:09:45
1997 yep ,I gess the replacement part wont let that happen .
ddg
01-26-2005 18:14:19
 Re: Cummings 5.9 Engine in reply to GRL, 12-29-2004 19:53:41
That has happened quite a bit on Dodge pickups with the 12 valve Cummins engine. There is a fix to prevent it from happening. Go to www.turbodieselregister.com and look for "killer dowel pin" or "kdp"
