Restoration & Repair Tips Board
Case VAC axle seals
dorf
01-14-2005 16:53:15
Could I get help on the part number for the axle seals for the Case VAC (1951) and where can I buy them for less then the fifty bucks a piece that Case/International wants?
CNKS
01-14-2005 17:54:37
 Re: Case VAC axle seals in reply to dorf, 01-14-2005 16:53:15
I am more familiar with the IH part of CIH, but if you have a place that sells bearings and seals, a specialty type place, they are likely to be cheaper. Or, NAPA is a possibility. They can cross the number, or if not available can measure them if they are not too garfed up. Those must be big seals, don't think I have ever paid more than maybe $25 for Farmalls, even from the dealer. The local bearing place is usually 30-50% cheaper. Won't the dealer give you the number?
don barnhart
01-16-2005 14:47:05
 Re: Case VAC axle seals in reply to CNKS, 01-14-2005 17:54:37
Will try the dealer for the part number. If any one knows the part number I would appreciate it.
Joe (Wa)
01-17-2005 14:25:29
 Re: Case VAC axle seals in reply to don barnhart, 01-16-2005 14:47:05
Case original p/n is VT3749, new p/n A30526 about $39.
Option, click on link, click on access to interchange data base, enter either of the above Case p/n. CW nr 25745, click on for dimensions.
Napa should be able to cross-ref & provide seal.
The only p/n that I can confirm correct is the original Case p/n, the rest is a number trail.
Joe
