IH QA-42A Snowblower
Bob
01-20-2002 14:08:06
I have a QA-42A snowblower attached to my Cub Cadet 126. Does anyone know how to remove the blade and shaft from the blower so I can replace the sprocket? The teeth are too chewed up for the chain to grab. Thanks.
BFarr
01-30-2002 15:24:58
 Re: IH QA-42A Snowblower in reply to Bob, 01-20-2002 14:08:06
Again. ihcubcadet.com is the place to go for excellent information
Just did mine this winter, remove chain, 6 bolts holding augerbearing to outside shell, pry auger out, remove approx 1/4 bolt which extends through auger to attach end spindle and gear to auger, I then used heat to expand auger tube and tapped plug out and replaced it with a used part bought from Don Vogt (see the site) Easy repair
sammy the RED
01-21-2002 04:35:23
ihcubcadet.com
