Restoration & Repair Tips Board
1965 allis chalmers b 10 lawn tractor
gene hale
01-29-2005 13:49:09
my 1965 b10 tractor has lost power to the rear wheels but the axel still has power and rotats in all gears can any one give helpfull advice on the subject?
jnewark
02-03-2005 04:18:32
 Re: 1965 allis chalmers b 10 lawn tractor in reply to gene hale, 01-29-2005 13:49:09
you could have one of 2 problems, on that tractor there is a axle tube that runs through the rearend, it has a bolt that looks like the wheel bolts,on the left hub, (sits @ about a 45* angle to the axle) that bolt rubs on the axle which is inside of the axle tube, if the bolt is too loose the axel will not turn, the other problem (which was a problem of mine) is the hubs which attaches the axel to the wheel has a key in it, after 4o years of use the hub and keyway get pretty torn up, I had to weld up the axle and grind a new keyway in mine, edventually I welded the hub to the axle, Good luck, those tractors are great workhorses...
