Restoration & Repair Tips Board
Cub cadet 1440 won't turn over
Anthony Pie
02-09-2005 12:37:56
Hi can anyone help me out here. My cub cadet wont start or even make a sound when i turn the key. i"ve charge the battery and still it won"t turn over. Got any ideas why and how to fix it?? ASAP need for plowing
Anthony
Bigdog
02-09-2005 19:29:23
 Re: Cub cadet 1440 won't turn over in reply to Anthony Pie, 02-09-2005 12:37:56
If you have an electric pto, make sure the switch is off. Check all the safety interlocks. One of them is probably not making. Also take a good look at your battery connections and make sure they are clean and tight.
Bob McC
09-01-2005 15:49:56
 Re: Cub cadet 1440 won't turn over in reply to Bigdog, 02-09-2005 19:29:23
I have am 8 yr old 1440 cub cadet …when the PTO is on and I engage the hydrostatic transmission it stalls after about 5 minutes. It can sit there with the blades running top rpm all day…no problem. Soon as I start cutting grass it’ll stall after about 5 min. We replaced all the usual suspects….new gas filter, air filter the dealer has looked at the carburetor….it’s OK. Any ideas? thanks
