Restoration & Repair Tips Board
Alternator or generator
Clay
02-15-2005 07:11:56
After digging in the archives I discovered that in order for me to repair my tach cable I need to find out if I have an alternator or generator.
How will I know and where are they located?
steve(ill)
02-15-2005 19:13:18
 Re: Alternator or generator in reply to Clay, 02-15-2005 07:11:56
most generators are steel case, painted black, about 5 inches in diameter and mapyb 8-9 inches long. There are two bolt terminals on the side marked "A" and "F". An alternator is normally aluminum case, maybe 6-7 inches indaimeter and probably not as long (5-6 inches) as it is in diameter. The terminals on an alternator usually consists of one 1/4 inch lug on the back that is the main charge terminal, and then a series of spade connector pins all in one block. there could be 2-4 pins close together with one connector block. Some alternators have an internal voltage regulator, some have an external voltage regulator. All generators have external black box (voltage regulator). The generator or alternator should be on the side of the motor at the front, driven by the fan belt.
clay
02-16-2005 05:41:29
 Re: Alternator or generator in reply to steve(ill), 02-15-2005 19:13:18
Thanks steve.
