Restoration & Repair Tips Board
JD B Question
Matt KS
02-23-2005 06:31:30
Hi guys & gals- I'm going to pick up a couple of B's. I think one's a '50 and the other is a '36. Neither one runs, however the '50 is capable of rolling on it's own wheels. The older one is a basket case and I'm trying to figure out how to unload it without a loader or another tractor. I'm thinking of making some stands with wheels that will bolt to the studs (that the fenders normally bolt to) on the rear axle housing . I would also have to make a stand for the front end.
Has anyone out there done anything similiar? Also if someone has a tape measure and B handy can you give me the measurement from center to center of each stud? Should be around 4" to 6" I would guess. Thanks!
36BinMN
02-23-2005 12:55:55
 Re: JD B Question in reply to Matt KS, 02-23-2005 06:31:30
I just noticed you are calling them "studs" they are accualy bolt holes.
36BinMN
02-23-2005 09:05:42
One more question. How do you want them measured, center to center or what?
36BinMN
02-23-2005 09:03:40
third party image
Hi Matt, This is the back of my 36B. Are you refering to the bolt holes I have circled in the pic or the ones closer to the center of the tractor? If none of those please point out which ones and I will measure them for you.
MattKS
02-23-2005 10:21:31
 Re: JD B Question in reply to 36BinMN, 02-23-2005 09:03:40
third party image
36B- Thanks for the offer! If it wouldn't be too much trouble while you've got the tape out would you mind grabbing these measurements?
36BinMN
02-23-2005 11:12:50
 Re: JD B Question in reply to MattKS, 02-23-2005 10:21:31
Will do!! I will post back later
MattKS
02-23-2005 12:46:38
 Re: JD B Question in reply to 36BinMN, 02-23-2005 11:12:50
Almost forgot- What's the diameter of those studs? They look like 1/2" but I can't tell for sure. Thanks again.
36BinMN
02-23-2005 12:53:22
 Re: JD B Question in reply to MattKS, 02-23-2005 12:46:38
third party image
Hi again, All measurements are to the center of holes. Hope this helps, If you need more info please ask and I will do what I can. I new you were going to ask what size they were (lol) I did not check with a bolt, but I am sure they are 1/2 in . If you need to know for sure I can drive out there in a day or two and check ( it is stored at a friends place about 8 miles away).
MattKS
02-23-2005 13:31:03
 Re: JD B Question in reply to 36BinMN, 02-23-2005 12:53:22
36B- This is great info. Thanks very much for your help. Don't worry about the stud dia. I'm going to assume it's 1/2", as I'm almost sure it is.
I'll post a picture of what I end up doing to make the tractor "trolly".
Matt
36BinMN
02-23-2005 13:59:02
 Re: JD B Question in reply to MattKS, 02-23-2005 13:31:03
That would be great to see!! and your welome.
MattKS
02-28-2005 07:16:13
 Re: JD B Question in reply to 36BinMN, 02-23-2005 13:59:02
Well I got the B's home. Had to make 2 trips with and the trailer I borrowed was too narrow so one wheel ended up riding on the side rail. I ended up placing the '36 wheels on pallets and stapping the palletts to the wheels so the would stay in place. The pallets slid off the trailer nicely, even the pallet riding the rail.
Now for the new problem. I knew the '50 needed the seal behind the clutch replaced. When when we started loading it antifreeze began running out behind the clutch. How could coolant be getting here??
36BinMN
03-01-2005 10:33:03
 Re: JD B Question in reply to MattKS, 02-28-2005 07:16:13
I am not sure how coolant got there, but the engine case must be full of it. You may want to start a new topic on the Deere page. Did the measurements I gave ya work OK?
