Restoration & Repair Tips Board
Cylinder liner rust pitting
Rob14
02-26-2005 18:26:43
I have a W4 McCormick. The liners are in good shape except the cylinder head was cracked. One of the cylinders sat with water in it as a result. This liner is pitted from the rust on the inside. How bad can this be and still leave the liner and pistons alone. Or is it no question it needs to come out. thanks Rob
dr.sportster
03-02-2005 15:11:48
 Re: Cylinder liner rust pitting in reply to Rob14, 02-26-2005 18:26:43
A piston can pass over stuff like that ok.Its only bad if lines and grooves run the lenght of the cylinder.The rings on a Harley pass over an oil hole [in some cases]without problem.
txblu
03-11-2005 05:44:09
 Re: Cylinder liner rust pitting in reply to dr.sportster, 03-02-2005 15:11:48
I agree. The time the piston takes to pass over a pit is small as compared to the stroke so compression gasses lost will be slight and probably non detectable.
As far as breaking a ring, I think if you have honed the cylinder and the sides are without pertubations sticking out, the ring will pass right over and not know it's there.
I'd do it in a heart beat.
My 2c
Mark
dr.sportster
03-13-2005 10:48:58
 Re: Cylinder liner rust pitting in reply to txblu, 03-11-2005 05:44:09
Yes txblu,And we both forgot to mention two strokes where rings pass huge ports in cylinder walls.
Bob02
03-01-2005 07:50:43
I would hone it to the maximum standard bore then see what you have. I the pits are still there I would be afraid of breaking a piston ring at some point.
cole in mo.
02-27-2005 03:47:57
Rob, I"ve worked on many rusted up engines that people just wanted to get running. If the pits aint as big as your finger tip I"ve had good luck with just a good hone job, clean the piston up good, put on new rings and fire it up. Sometimes they"ll smoke for a spell, sometimes they won"t. You will have to do some work on the head, as the valves will be rusted also. Look the cyl over close and make sure it didn"t freeze and crack, sometimes this will only show up after honing. luck.
