Restoration & Repair Tips Board
GEARS STUCK IN REVERSE (CAT D7)
abdul mulasi
02-27-2005 22:02:55
HI
WHEN ENGANGING GEARS 1, 2, 3 IT JUST REVERSE INSTAED OF FORWARD. IT SEEMS THE LINKAGES ARE NOT COODINATING WELL UNDER THE SEAT. ANY ONE HELP.
NB THIS IS OLD MACHINE 1965, THE MOTOR IS GOOD AND THE TRANSMISSION IS GOOD...HOPEFULLY!
THANKS
MSM
03-05-2005 14:01:59
 Re: GEARS STUCK IN REVERSE (CAT D7) in reply to abdul mulasi, 02-27-2005 22:02:55
Should be another lever to change from foward to reverse. Travel speed is changed on the transmission,and direction is changed by using the reverser. This is assuming it has a reverser,some did and others didn't.
hector gemme
02-28-2005 13:04:12
HI YOUR dozer is he power or stender shift and what serie. HECTOR
