Restoration & Repair Tips Board
Cub oil filter question
jmh
03-06-2005 04:59:35
Need to replace the oil filter in a 51 cub. My question is:
Does the filter have any type of washers or springs on the long bolt that goes thru it? I know it has a sealing washer between the head of the bolt and the cap of the filter. Do I put the washer on the bolt, stick it thru the cap, slide the filter on, then assemble this into the block? Hope this makes sense. Thanks for your help. jmh
Bigdog
03-06-2005 09:01:06
 Re: Cub oil filter question in reply to jmh, 03-06-2005 04:59:35
No springs or washers. Your description is correct.
