730 JD 1959
Donnie E. Reavi
01-25-2002 13:40:50
how do you adj power steering it wonts to turn on its own to the left and hard to turn to right
C George
01-25-2002 20:22:32
 Re: 730 JD 1959 in reply to Donnie E. Reavis, 01-25-2002 13:40:50
Don, There is an adjustment for just that problem. I would STRONGLY suggest you get a service manual for it as it describes it better than I can. It is easy as all you do is loosen the bolts slightly on the valve body (on the side of the unit near the top) and tap it gently front or rearward ( its been a long time since I've done it) then tighten the bolts. Go just a VERY little at a time as they are touchy
