Restoration & Repair Tips Board
Lift problems on Ford Jubilee(NAA)
Teresa Patterso
03-09-2005 06:20:53
We recently bought a Jubilee with lift problems and are having a hard time figuring out what is wrong. We thought at first it was just trash in the system so took it apart and cleaned it out. Seemed to help and the lift at least would go up and down, but will not lift any type of load. It doesn't bleed down once it is up, just won't pick up any weight. Please help...any advice is greatly appreciated. Thanks
Dewane
03-09-2005 07:47:55
 Re: Lift problems on Ford Jubilee(NAA) in reply to Teresa Patterson, 03-09-2005 06:20:53
Check your piston. It is location under your seat. Raise the plate and you will see the slave or piston. Normally cleaning with light sand paper will repair it properly. But to put a kit in is about $100. This repair my Ford 600 with the same problem
