Restoration & Repair Tips Board
throttle problem to30 ferguson
frustrated fat
03-13-2005 14:18:51
tractor ran bad, put rebuild carb on thinking it would cure-no way. tractor runs wide open no throttle control, ran adjustment rod from one end to the other on carb to governor no difference help me please
Adam L
03-15-2005 04:27:12
 Re: throttle problem to30 ferguson in reply to frustrated fat man, 03-13-2005 14:18:51
If you have had it apart, the governor may be put to gether wrong, when the tractor is running see if you can manually move the carb lever by hand and see if that helps, but it would almost have to be the carburator or the governor.
