Restoration & Repair Tips Board
Bent Hydraulic Cylinder Rod-14 Degrees-Help
KJ7VJ
03-29-2005 07:44:19
Hi I still have my 1973 White 2-63-15 tractor backhoe, but last week I was doing a trench job for a neighbor and I heard a terrible chattter noise and when I brought the dipper up out of the ditch the hydraulic cylinder on top which runs the dipper had a bend in it. It is almost fully extended and of course won"t retract because of the bend. The bend is about 10 inches from the bottom of the cylinder and is about a 14 degree bend. Can this be straightened out in some kind of press or what do you hydraulic guys or experts suggest? The cylinder is 2 inches in diameter and about 36 inches long. What might it cost to replace the cylinder rod and seals? Anyway thanks for any responses or help. Take Care.
Dennis/Ohio
04-09-2005 01:52:00
 Re: Bent Hydraulic Cylinder Rod-14 Degrees-Help in reply to KJ7VJ, 03-29-2005 07:44:19
Hi,
If you put a dial indicator on the rod. you'll know how far you went past center on each push. Mark the top of rod with magic marker. The idea is not go too far by keeping track of how far you've gone each push.
Also what probably bent your cylinder is pressure caused by a different cylinder on the machine. Thats what secondary relief valves are for. If your machine has these secondary reliefs, they aren't working.
Best, Dennis.....
JMS/MN
03-29-2005 08:08:25
All you need is a shop press, two 'V' blocks, and a straightedge. That degree of bend should be easy to reverse. You'll have to go a bit over center so when it springs back, it ends up right. Go to far, just flip it over and push it back. The better the job you do, the less likely the seal will fail.
