Restoration & Repair Tips Board
restoring cub with a leaking seal
Eddie Collison
03-30-2005 16:08:39
I am pulling down a 1948 Farmall Cub and the pulley doesn"t have a screw on the end of the shaft. How do you remove the pulley does it screw on or is there another way bescause it is very tight and not budging? Can anyone help?
Thanks if you can!
Eddie
Georgia Boy
04-13-2005 09:06:48
 Re: restoring cub with a leaking seal in reply to Eddie Collison, 03-30-2005 16:08:39
Be sure to pull from behind the pulley, otherwise you will break the flanges. I had to buy an OTC large pulley puller, or it may be called a bearing separator. It took a lot of effort and some heat, but once I heard it pop loose it came right on off. My crankshaft on my A is threaded so I was able to use a bolt and some heavy duty washers to put it back on again.
