Restoration & Repair Tips Board
Firing Order for a Farmall 140
John Elwell
04-03-2005 18:16:37
What is the firing order for a Framall 140? Is the # 1 cylinder nearest the radiator or the transmission? Where is the # 1 and # 2 connection on the distributor?
Thanks for your help?
John
Bob M
04-04-2005 05:59:31
 Re: Firing Order for a Farmall 140 in reply to John Elwell, 04-03-2005 18:16:37
#1 cylinder is at the front of the tractor (closest to the fan).
Firing order is 1-3-4-2.
Usually "#1" is molded right into the distributor cap next to the #1 terminal. But if not, it's the terminal at about the 2 o'clock position with the cap installed on the distributor. Firing order goes CLOCKWISE around the distributor from #1.
