Restoration & Repair Tips Board
perkins flamestart wiring
frank dubois
04-05-2005 09:11:19
i'm putting a flamestart kit on the intake manifold of my perkins 4-108 to help with cold starts. No instructions came with kit so does anyone know what to wire the flame injector to. SHould I wire it to the solenoid so it is only energized while the starter is cranking or should it have its own separate circuit with a momentary switch?? Thanks for your help. FD
RickB
04-05-2005 18:30:16
 Re: perkins flamestart wiring in reply to frank dubois, 04-05-2005 09:11:19
Older NH skidsteers with Perkins had the manifold heaters wired in parallel with the starter solenoid as you suggest. I think it is important to preheat a little before cranking in severe cold and have altered a couple units with a momentary switch and an additional heavy duty relay so preheating can be controlled separately from cranking. Also, preheating is skipped when not needed.
