Restoration & Repair Tips Board
Ford 2000 doesn't run
snoopy
04-05-2005 18:40:59
The Ford 2000 cranks and then sputters and dies. It then will crank again but continues to run as if it is not getting fuel and dies. It was previously running fairly well until the float stuck and allowed gas to run thru carb. I then tool the Marvel Schebler carb off and took it to dealer at which time new parts and new float was installed in the carb. Since then it runs as if not getting fuel. I know it is getting fuel as far as the fuel settling bowl. Anyone have any suggestions?
Jack
danielg
04-06-2005 17:33:35
 Re: Ford 2000 doesn't run in reply to snoopy, 04-05-2005 18:40:59
does i have a fuel filter? if so replace that. it doesnt take much for they clog up.that dont work tke the fuel line off from the carb to the sediment bowl and claen out with clothes hanger!! Hope this helps
