Restoration & Repair Tips Board
Ford N9 stalls unless choke on
Jeff Wain
04-29-2005 08:44:26
Hello, My 1941 Ford N9 tractor idles find when I increase RPM with the throttle it stalls unless I hold the choke out. Any Ideas before I disassemble the carburetor?
Thanks in advance
9NJoe
05-04-2005 10:53:42
 Re: Ford N9 stalls unless choke on in reply to Jeff Wain, 04-29-2005 08:44:26
Jeff,
It sounds like your power circuit is too lean. If it idles OK, that says the carb is basically OK. So try backing out the big screw on the carb about 1/2 turn and see if that helps. If not, then you may have some crud in there and you will have to dissassemble and clean.
Joe
old
04-29-2005 09:23:54
Your on the right track the only way I know to fix your problem is to rebuild the carb. You might get by with pulling out the adjustment screws and spraying carb clean in it, also if you do so have the drain plug out of it, its on the bottom of the carb.
