Restoration & Repair Tips Board
Kubota L4310 stuck in low range
chasc
04-30-2005 14:55:20
My L4310 Kubota seems to be stuck in low range; it was hard to move from high to low and now I can"t get it out of low. Until I can get to a mechanic after the weekend, I wonder if anyone has any tricks to unfreeze it. Thanks.
MSM
04-30-2005 15:43:53
 Re: Kubota L4310 stuck in low range in reply to chasc, 04-30-2005 14:55:20
If it is a 4wd model,make sure it is out of 4wd before shifting ranges. Variations in tire wear or air pressure tend to bind up the trans slightly making it hard to shift. Also being off of hard pavement or packed ground will aid in shifting.
chasc
04-30-2005 16:15:16
 Re: Kubota L4310 stuck in low range in reply to MSM, 04-30-2005 15:43:53
It is a 2wd but I appreciate your suggestions MSM.
