Restoration & Repair Tips Board
JD R Hubs Loose
Mark Wengert
05-15-2005 18:09:10
I have a JD R and when I put new tires on it I noticed that the hubs have been moving in and out on the axle wedge. Someone told me to take the wedge out and grind the end down and it will draw up more. Sounds good in theory but will it work or will it mess up the alignment of the bolt threads. Any and All input will be GREATLY Helpfull.
Thanks,
Mark Wengert
Burlington Flats, NY
JDTRUBLE
05-17-2005 20:47:58
 Re: JD R Hubs Loose in reply to Mark Wengert, 05-15-2005 18:09:10
I had the same problem on some of my Tractors the best thing i can tell you is to get a good breaker bar and tighten them as tight as you can DO NOT rely on a impact wrench!!
