Restoration & Repair Tips Board
18hp briggs stratton starter repair
rontof
05-15-2005 20:49:37
I need to replace the starter gear and I can"t figure out how to do it without removing the starter and I don"t see how it comes off. Do I need to remove starter to replace the gear? I cannot get the pin driven out of the shaft!
Thanks for your help on this..
Ron
cliff
06-04-2005 14:25:16
 Re: 18hp briggs stratton starter repair in reply to rontof, 05-15-2005 20:49:37
be careful driving pin out with starter on machine, you could bend the shaft. briggs and stratton sells a universal swivel attachment for removing the starter mounting bolts. this way you can support the shaft for driving out the pin.
old
05-16-2005 05:57:29
You need to pull the flywheel to replace that gear
