Restoration & Repair Tips Board
Grease removal
JackT
05-16-2005 06:49:14
Anyone have suggestions for EASILY removing old, hard caked grease? I'm talking about the thick, dried stuff you just about have to chisel off. I haven't found any sort of spray or soak solvent that works effectively. Burning it off with a torch stinks and scorches the paint. Suggestions?
Thanks,
JackT
Eric Stevens
06-15-2005 22:49:17
 Re: Grease removal in reply to JackT, 05-16-2005 06:49:14
Hot water with TSP trisodium phosphate which can be purchased at the hardware. Better way would be to incorporate the idea of a pressure washer with a soap induction system using the tsp. This method may leave your paint chalky though.
Mac
05-18-2005 17:14:48
Oven cleaner from the dollar store. About a dollar a can and really works. May discolor paint if left too long.
Weirsdale George
05-17-2005 04:38:52
There is no easy way, only elbow grease. I have used all sorts of putty knives, custom scrapers and dental probes to remove every bit of the waxy residue possible, then use Gunk with a very stiff bristle brush. Probably will have to repeat the scrubbing part a couple times.
Would a steam cleaner work?
Little Dave
05-16-2005 21:35:52
Jack I used a sharp wood chisel and a sharp knife and then washed it with degreaser.It is just one of the nasty jobs that goes with working on a tractor. Sand blasting don't even cut it very well.
msb
05-16-2005 21:46:17
 Re: Grease removal in reply to Little Dave, 05-16-2005 21:35:52
Some say MEK (methyl ethyl ketone) but its rough on the liver if you get it on your skin so wear rubber gloves.
mike brown
05-21-2005 08:12:04
 Re: Grease removal in reply to msb, 05-16-2005 21:46:17
Hot high pressure washer. Expensive to buy, but maybe one can be rented or hire someone with one to come clean your machine.
DOUGLAS ROY
05-22-2005 20:06:32
 Re: Grease removal in reply to mike brown, 05-21-2005 08:12:04
You need to scrape the big stuff , but after that use OVEN CLEANER.
Most any kind works but MR. Muscle works the best. Its meant to work on cold surfaces
