Restoration & Repair Tips Board
Flash rust removal and gas tank cleaning
Kevin Brooks
05-16-2005 12:30:02
I have repeatedly cleaned my M's gas tank with muriatic acid followed by several water rinses to remove the acid, and then moister remover to dry it. However, whenever I check the insides of the tank, thinking that I'm finally done cleaning, I find rust all over. I'm guessing this is flash rusting as immediately after my acid cleaning/water rinse the insides are shiney clean. How do I prevent this flash rusting from occuring long enough so I can get a proper sealant applied? Any help appreciated.
just did mine
05-29-2005 18:14:09
 Re: Flash rust removal and gas tank cleaning in reply to Kevin Brooks, 05-16-2005 12:30:02
rinse with mek twice, then use your sealer. I used redcoat. Most of these polymers will cover over the light surface rust you are discribing with out any problems. But if you have a lot of flaky rust this needs to be removed.
StumpZ
05-26-2005 07:06:45
I took my tank to a local radiator shop and they cleaned and coated it. Best $50 I have spent in a long time.
jake3
05-19-2005 08:48:18
You made a problem when using acid, the way yo go now is immediatly after dumping the acid rinse with water. Next absorb as much water with cotton then coat the inside with WD-40 which will prevent rust due to its water displacing properties. When ready to put a coating liner wash out with alcohol.
