No start Herc engine in an OC3
P0LK CRAWLER
02-04-2002 20:30:05
1953 OCE: had mag professionally repaired; rebuilt carb per YT article instructions; fresh gas; new 8V battery; hit starter button; engine spins OK and spark to all four plugs but no start'; a little starting fluid in #1 cyl produced pop and bang,no start; no smell or sight of fuel on plug terminals; where do I go from here? Thanks PC
John S-B
02-06-2002 14:39:43
 Re: no start Herc engine in an OC3 in reply to P0LK CRAWLER, 02-04-2002 20:30:05
I'd start at the beginning, make sure if you have a shut off valve in the line it's open. See if you are getting fuel to the carb. If you had the lines off for a while an insect could have plugged the line. Also check fuel filter or pump if it has one.
polk crawler
02-09-2002 21:34:03
 Re: Re: no start Herc engine in an OC3 in reply to John S-B, 02-06-2002 14:39:43
John: carb overhaul was not complete; missed one jet; cleaned it out, engine took off after 2 yrs non-use. Thanks for the reply PC
