Restoration & Repair Tips Board
Bobcat Air in Hydraulic lines
doug burnet
06-01-2005 17:16:15
Hi,
I replaced a blown hydraulic line. the bobcat runs fine now, except when using any hydraulic controls there is a groaning sound. the dealer said that the system is self-bleeding and by idling the engine this would bleed the lines and stop the noise.
so far, this hasn't improved. it's a model 533.
1. should i idle the motor for longer?
2. is it ok to run the machine even though the noise is still there?
3. words of advice/encouragement?
chvet73
06-03-2005 17:53:08
 Re: Bobcat Air in Hydraulic lines in reply to doug burnet, 06-01-2005 17:16:15
Just like the last post said. You have to run through each cyliders range to clear out the air.
doug burnet
06-03-2005 18:45:52
 Re: Bobcat Air in Hydraulic lines in reply to chvet73, 06-03-2005 17:53:08
Thanks!! Worked just as you said. This is the first time i've ever posted on ytco and i really appreciate the help. doug burnet
ccwken
06-01-2005 19:47:37
If you idle the engine and exercise the cylinders through their complete range, it should bleed the lines. Simply idling the engine only runs the pump.
