Restoration & Repair Tips Board
How Much Does A Farmall M Weigh?
Adam Zich
06-01-2005 21:24:31
How Much Does A Farmall M Weigh? I was wondering if I could move a Farmall M with the Trailer I have. I only need to move the Tractor like 9 miles. Thanks, -Adam Zich
RustyFarmall
06-02-2005 09:33:05
 Re: How Much Does A Farmall M Weigh? in reply to Adam Zich, 06-01-2005 21:24:31
What kind of trailer? A common tandem axle bumper hitch trailer is rated at 7,000#, since the trailer itself will weigh 2,000#, that only leaves 5,000# to play with. The tractor could weigh as much as 6,000#, You do the math. Also, the trailer may not be wide enough to allow the rear tires between the fenders.
Charles Parkq
06-02-2005 06:33:13
You can figure between 5,000 lbs. to 5,500 lbs. Depends on several things like wheel weights or fluids in tires, etc. This is pretty accurate.
Also, you research a lot of this from the archives. CNKS posted this answer some time ago.
